Difference between stage 2 and stage 3 kits
Old 03-05-2011, 11:14 PM
thornious's Avatar
thornious
thornious is offline
Default Difference between stage 2 and stage 3 kits
SCREAMIN ’ EAG LE PRO STAGE III KIT –
103 CUBIC INCH es
This 103 bolt on kit is designed to provide increased performance
enhancements at an attractive price range that will
work with your Original E quipment heads. Kit includes 3-7/8"
diameter highlighted cylinders, forged aluminum 10.5:1
compression ratio pistons, an SE259E cam supported by
high-performance valve springs along with the appropriate
Perfect-Fit Pushrods and gasket kit. In addition kit includes
our “must have” E FI Super T uner to provide the correct
calibration for appropriate tuning abilities.
For race application
only.
Fits ’07-later T win Cam equipped models. Also fits ’99-’06
Twin Cam models equipped with 4-5/8" stroker flywheels.
27513-08B
Black. $1,499.95
27514-08B Silver. $1,499.95
C. SCREAMIN ’ EAG LE PRO STAGE II KIT –
103 CUBIC INCHES *
The Stage II Big Bore Kit provides the parts you need to
improve the track performance and horsepower of your
EFI-equipped model. T he kit increases the displacement
of your T win Cam-equipped model from 96 cubic inches
(1584cc) to 103 cubic inches (1690cc). Kit includes Stage II
(SE-255) cams, 3-7/8" Big Bore cylinders, 3-7/8" Big Bore
flat top pistons a high-performance clutch spring, and all
mounting hardware and gaskets. Just add your choice of a
Screamin’ E agle High-Flow or Heavy Breather Air Cleaner
(sold separately)
for maximum track performance. R equires
separate purchase of primary cover gasket. N ot all components
shown. All E FI-equipped models require E CM calibration*
(priced separately)
. Separate purchase of cam spacers
is required. See service manual for proper procedure and
cam spacer part numbers.
For race application only.
Fits ’07-later models equipped with a T win Cam 96 engine.
29893-07A
Black. $759.95
29894-07A Silver. $759.95
Now can anyone tell me why the differnce in price between the two kits once the tuner is removed from the price. Dealer said they would take off around 400 for the tuner since I already have it. Would'nt I need new push rods anyway, so that would be a wash.
Why does the stage 3 kit make so much more hp and torque? Are the cams and springs adding that much more?
Kinda confused
Old 03-05-2011, 11:23 PM
XARAN's Avatar
XARAN
XARAN is offline
Compression is why it makes more Hp
The Stage 3 kit has forged hi comp pistons
Old 03-05-2011, 11:40 PM
thornious's Avatar
thornious
thanks man I have been looking at this for 2 days now and I kept missing the pistons description.
Old 03-06-2011, 12:33 AM
TheNameIs"B"'s Avatar
TheNameIs"B"
TheNameIs"B" is offline
bout 65 miles a tank!
Old 03-06-2011, 10:47 AM
thornious's Avatar
thornious
Still not sure about the extra money though. Seems those psitons can't be worth an extra 2-3 hundred.
Old 03-06-2011, 11:30 AM
tke899's Avatar
tke899
tke899 is offline
I think the head work is where the extra money comes into play. Like you said along with the tuner and high compression pistons I think make the price difference seem about right. Is that the installed price? Doesn't look like either build includes a tune either so add an additional 3-400 for that.
Old 03-06-2011, 10:31 PM
thornious's Avatar
thornious
nope that was purley a parts quote directly from the SE parts catalog.
DK Custom - ST
Vendor For Sale Classifieds
10-05-2018 02:45 PM
DK Custom - ST
03-06-2018 03:57 PM
squidly_c
03-14-2015 04:18 PM
rocknrick
Dyna Parts
10-01-2009 07:47 PM
P'colaHarley-17RGS
Exhaust System Topics
02-27-2009 12:17 PM
Quick Reply: Difference between stage 2 and stage 3 kits
