Shock or Transmission Leak?
I own a 2007 Softail Custom and had it on a lift giving it a good cleaning when I noticed red oil dripping off the end of the right shock. My initial thought that it was transmission fluid which is red. I could not find any leaks around the drain plug or any other part of the bike. I then wondered if it might be the shock leaking. I thought I would pick everyones brain before changing the transmission fluid in order to inspect the gasket around the transmission drain plug. I really don't think that's the problem since I always put a new gasket on each time I change the fluid.
Any input would be appreciated.
Thanks
Thanks
So you run ATF in your gear box? seems a little light for a gear box. Does it shimmy in the rear end when you hit a good bump. You should see dust/oil around one shock over the other if its leaking and it will react badly when you hit bumps if the oil is leaking out of the shock. Time to get under there and do some more investigation.
