Front end not straight
My Deluxe front end dont look straight, the bike tracks great, no pulling to one side or anything like that, its just that when your going in a straight line the bars are ever so slightly out, and I mean only a little, a mate of mine couldnt even see it, but I know its there and its pissin me off.
The bars are not bent or anything so I dont know what it could be other than its not been put together right, there are no signs of it being dropped either.
Any ideas
Any ideas
After I was cut off by a car and plowed into it my front end was out of whack, but like you described, only a little bit. No one but me noticed.
You ever crash a bicycle and the wheel went crooked? Same principal. To fix mine I loosened all the triple tree bolts and tweaked it all until it was perfect, then tightened it all back down.
Not sure why yours would be crooked, but that might do the trick. When I did it I had access to a rack and a wheel chock so the bike was perfectly strait. When I was finished, the little crook was gone.
Perhaps a professional will come on here and have a better idea.
I had to have the tank changed on my '10 Heritage, after I got it back I would have sworn the front end was jacked up. WTF, right? Turned out the console was not put back on straight, just a little bit crooked and it gave the illusion that my front end was not straight. Moved the console about an 1/8" and all was well. It bugged the S#*t of me till I figured it out.
Any ideas
Any ideas
Usually the problem is the bars are crooked because of the rubber bushings. You can put your tire against the curb and tweek the bars till they are straight...but they are not likely to stay. If it bothers you that bad you can get some poly bushings or just ignore it.
Yeah i agree with the bushings.. when i crashed my Sportster in 08, i picked it up and the handlebars looked straight to everyone, but i saw the change and felt it too.. turns out it was a compressed bushing.. the bushings are in your tripletrees, between the bottom of the handlebar risers, and the bolt that holds them on underneath.. you can get them from HD, but other hardware stores sell them too.. idk the part number..
Any ideas
Any ideas
