Compression Ratio
03-24-2011, 12:28 PM
Compression Ratio
Can anybody tell me the end compression with 9.5 and / or 10.5 pistons when using unworked SE heads (9.5-1)??
03-24-2011, 12:57 PM
03-24-2011, 01:25 PM
Quote:
Originally Posted by
swensos
I noticed in a previous thread you were talking about using an EV-27 cam. Don't use that cam with high compression pistons. It builds up too much cranking pressure. Send Andrew's an email asking them what cam they prescribe for your build. If I remember correctly they told me an EV-48 but I went with a Crane cam instead.
03-24-2011, 01:37 PM
not doing ev27
I'm going to use Comp's Vthunder once I figure out the end CR #'s probably the 3030
03-24-2011, 01:49 PM
swensos
I looked up the v thunder 3030. Sounds like a good choice.
03-24-2011, 02:17 PM
KumaRide
that calculator is out of my league..
03-25-2011, 06:31 AM
swensos
My suggestion is to not worry about the final compression ratio. As long as you pick the right cam for your piston choice, you'll be fine.
machinehed
01-06-2020 06:42 AM
saz
Engine Mechanical Topics
20
01-23-2015 02:15 PM
blksoftail
Exhaust System Topics
07-15-2011 11:30 AM
Trex
11-17-2010 06:41 AM
Brettfullthrottle
EVO
07-06-2010 12:35 AM
