Harley screamin eagle heavy breather black 00-10
Old 03-26-2011, 07:35 PM
TattooBill's Avatar
TattooBill
TattooBill is offline
Default Harley screamin eagle heavy breather black 00-10
Interested in adding this to my "10" Lo. Am I going to have any tuning issues with this? I also have the Screaming Eagle black pipes
thanks
Old 03-26-2011, 07:55 PM
MCSarge's Avatar
MCSarge
MCSarge is offline
Once you free up the incoming air you will have to use some type of tuner to get the bike running like it should. But on the good side a good tuner, SE Race Tuner, Thundermax, PC3 or PC5 will let the bike run cooler and give you a little more power.
Read a few posts on this subject here and you'll get all kind of good info. Good luck on your project.
Old 03-26-2011, 08:15 PM
Recon Dad's Avatar
Recon Dad
Recon Dad is offline
I went with the TTS Master Tuner with a dyno tune when I did the Stage 1.
Very happy with the results. Bike is a torque monster and slips into 6th gear at 50 mph.
When stock I never put it in 6th until around 65 mph.
Some say the stock ecm will adapt and you do not have to tune?
Old 03-26-2011, 09:08 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
The stage 1 will work just fine with it. The ecm will adjust to it, mine runs perfect.
Old 03-26-2011, 09:25 PM
Recon Dad's Avatar
Recon Dad
Nice looking bike!
Old 03-26-2011, 09:41 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
Originally Posted by Recon Dad
Nice looking bike!
Well thanks man!
Old 03-26-2011, 09:51 PM
jbg's Avatar
jbg
jbg is offline
You'll probably run fine without any fuel management. However it may still run a little hot and lean. It definitely wouldn't hurt to add some Fuel Management. If you're not doing anything more than Stage 1 then I recommend the V&H FuelPak. I've used on my 3 bikes and never had an issue. Good luck.
Old 03-26-2011, 10:16 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
jbg, you are correct that a fuel management system is always an upgrade. As far as running hot and lean with just stage 1, it dosen't.
I had the same concern and when I say it runs perfect like I have it, it's not an opinion. I have had this checked thoroughly and I have been running this set up just about 7 or 8 months now.
I woulda said the same as you if I didn't see it for myself bro.
Old 03-26-2011, 10:37 PM
Recon Dad's Avatar
Recon Dad
My bike ran lean and hot stock. I had burns on my legs from the bike sitting for red lights or running in rush hour traffic. I also did a lot of slow speed escorts and parades with the oil bubbling up.
If I would never do stage 1, I would do fuel management on the stock bike to keep the bike running cool.
Old 03-26-2011, 10:59 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
I agree, I'm running stage 1. Good advise! You guys probably know more about this than I do anyway, I'm just sayin what is happening with my set up. You could probably bury me in the performance knowledge, so I'll bow out now lol.
Quick Reply: Harley screamin eagle heavy breather black 00-10
