Woods TW-555 VS. Andrews TW55
Old 05-29-2011, 03:07 PM
JBourquin's Avatar
JBourquin
JBourquin is offline
Default Woods TW-555 VS. Andrews TW55
Has anyone run the Andrews TW55 cams? For what I can tell they are pretty close to the specs of the Woods TW-555 for about $100 less. Was about to pull the trigger on a set of Woods but for the price difference, is there much of a performance difference? I'm not real knowledgeable when it comes to cams, do the few degree differences make that much of a difference in how they work? Would a 4* key bring the Andrews closer to the Woods specs?? Thanks.
Woods TW-555:
Timing @ .053: 21/41 43/19
Duration: 242
Lift: .555
Lift @ TDC .189 .178
Andrews TW55:
INTAKE Open (in degrees): 22
Close (in degrees): 46
Duration at .053 (in degrees): 248
Duration at .020 (in degrees): 283
Valve lift: .550
Lift at TDC: .197
EXHAUST Open (in degrees): 52
Close (in degrees): 20
Duration at .053 (in degrees): 252
Duration at .020 (in degrees): 292
Valve lift: .550
Lift at TDC: .181
Old 05-29-2011, 05:52 PM
jaysonL's Avatar
jaysonL
jaysonL is offline
I'd contact Woods, and Andrews and talk to them . I read somewhere that Andrews actually grinds the cams for Bob Woods . Don't know if that is true or not . But I would bet that they could explain everything to you .
Old 05-30-2011, 12:52 AM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
i here good things about those woods cams, i have andrews 37 in mine,go good,lumpy!
lionsm13
04-13-2019 07:22 AM
HDSAE60
Engine Mechanical Topics
23
07-09-2017 05:01 PM
qtrracer
04-09-2015 04:32 PM
07 dyna man
01-24-2010 01:13 PM
rredneckn
02-23-2008 06:21 PM
Quick Reply: Woods TW-555 VS. Andrews TW55
