Engine Oil in 2011 Fat Boy
I have a new 2011 Fat Boy.
At 500 miles I drained the oil and put in HD Syn3
The manual says it takes 3.5 quarts.
When I drained it, only 2 quarts came out.
I then put in 3 quarts and it showed full.
Did I get a bike new from the dealer with only 2 quarts of oil?
I know the filter holds some..but not 1 1/2 quarts?
Have I been driving the first 500 miles without a full oil supply in my engine?
Will this have done any damage?
What should I do next?
2.5 quarts would have come out with a simple drain and filter change.
Adding 2.5 quarts would most likely shown as half way between Add - Full.
Putting the 3 quarts is fine. Don't panic go out and ride.
The 3.5 quarts is the number if the engine was bone dry, purged of all oil.
