Vibration noise from Speedo...(ROCKER)
Has anyone else experienced a vibration noise coming from the speedometer at certain rpm's? I have an 08 Rocker and when I reach certain rpm's I get this annoying rattling sound coming from the speedometer unit. I know it's coming from there because when I grab it, it stops. The speedo unit itself does have a little play in it when I try twisting it back and forth. I have taken it off, but unfortunately, i see no way to tighten it up. Any ideas?
Thanks
Thanks
my 08 does this also, i hate the vibration!! i looked for 6 months before i found it. i took the console off and see the spedo is mounted by two plastic clips. dont know what to do, thought about removing the spedo and putting some blue RTV (silicone sealer) on all the contact points and reinstalling. maybe the rtv would dampen some of the vibrating.
i am open to any info also.
thanks
Pat in Tennessee
2008 Rocker C- FXCWC
SE Stage II 103 Cu. In. Big Bore Kit (1690 cc) 3-7/8”
SE Pro 4-3/8” Stroker Flywheel and Rod Assy.
SE 10-1/2:1 Flat Top Pistons
SE Pro 58mm EFI Throttle Body
SE 255 Cam (Torque)
SE Roller Rocker Arms
SE Roller Tappets
SE Valve Spring Kit
SE ST Spark Plugs
SE 10mm Spark Plug Wires
SE Pro Tuner Kit
SE Performance Clutch
Vance and Hines Big Radius Exhaust
SE Stage 1 Air Cleaner Kit
SE Hi Flow Billet Air Cleaner with 103 Medallion
FXCW Luggage Rack Kit (Now Chrome Plated)
FXCW Seat
Mustang Sissy bar Pad (VSRC)
Custom Fabricated Sissy Bar (polished stainless steel)
H-D Flames Footpegs
H-D Chrome Voltage Regulator Cover
Custom Stainless 1” Tank Lift
Kuryakin ISO Grips
Comagination Head Light Modulator
Scorpio SR-i901 Active Security System
H-D Windshield
H-D Chrome Shift Rod
thanks
Pat in Tennessee
SE 255 Cam (Torque)
SE Roller Tappets
SE Valve Spring Kit
SE ST Spark Plugs
SE Pro Tuner Kit
FXCW Seat
H-D Flames Footpegs
Kuryakin ISO Grips
H-D Windshield
