Harley Springer 4.5 Deg Rake Kit
Old 11-14-2012, 03:05 AM
chillo's Avatar
chillo
chillo is offline
Here you go... My 2011 Bones just finished modding. Fitted the Vulcan Engineering 7.5 Deg rake kit and it still handles awesome.. Looks way better than stock too, in my opinion...
File Type: jpg
  #62
Old 11-14-2012, 05:50 AM
brettnbama's Avatar
brettnbama
brettnbama is offline
any wobble at highway speeds?
  #63
Old 11-14-2012, 09:59 AM
medina charlie's Avatar
medina charlie
medina charlie is offline
chilo that is what the frontend of a springer should look like. if I new about this kit earlier, I would have never sold my springer. ...perfect!
  #64
Old 11-14-2012, 10:09 AM
chillo's Avatar
chillo
chillo is offline
Cheers Charlie... When I stand it next to a stock Bones, the difference is amazing...
brettnbama: No difference to handling or any wobble at all speeds...
  #65
Old 11-14-2012, 11:49 AM
DC Mike's Avatar
DC Mike
DC Mike is offline
This is really the measurement that matters...
The Trail is the distance between where the steering axis hits the ground and where a vertical line down from the center of the front axle hits the ground.
You want to keep it between 4" and about 6". If you get less than 4" it will handle great at slow speeds but death wobble at freeway speeds. If you get more than 6" you will have trouble balancing it at slow speeds and it will handle sluggish at freeway speeds.
  #66
Old 11-14-2012, 12:23 PM
20Springer04's Avatar
20Springer04
20Springer04 is offline
6th Gear
I have an FXSTS 04 and have the same rake kit you have and my trail came out to about 1.5". What is the trail on your CB? I don't get the speed wobbles but when in a turn at highway speed, if there are bumps on the freeway my fork flops. The higher the speed the worse it gets. Are you experiencing this at all? I think I'm going back to factory rake unless I figure out why it's doing it. I'm pretty sure it's because of the lesser trail.
  #67
Old 11-14-2012, 06:53 PM
brettnbama's Avatar
brettnbama
I really want to do this, but am afraid of it causing problems
  #68
Old 11-14-2012, 08:12 PM
chillo's Avatar
chillo
chillo is offline
Are you sure you fitted the 7.5 Deg rake kit? As I believe the FSXTS uses a 4.5 Deg kit from Vulcan. The trail with the 7.5 Deg kit on my FLSTS comes in at just under 5''. It did handle slightly different when I first rode it after the install, but you get used to the difference after a few miles. I must stress that it behaves great around the City streets and Country roads...and when I gun it on the motorway, it still behaves perfectly. When you installed your kit, did it feel good and tight with the new bearings..? I experienced no real problems with the install, except removing the original stem was a PITA. The kit I received was very well engineered and the ride is great. Hope you get it sorted...
  #69
Old 11-14-2012, 09:05 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I just wanted to say (without addressing ANY rake and trail issues), the bike looks fantastic.
Originally Posted by chillo
  #70
Old 11-14-2012, 09:22 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
One of the prettiest ***** in the forum. Well done sir, well done!
Quick Reply: Harley Springer 4.5 Deg Rake Kit
