Adjusting the rear shocks
Old 08-19-2011, 12:20 PM
fcsallan's Avatar
fcsallan
fcsallan is offline
You people put too much thought to this. Turn the shock, take a ride. let your *** decide. Simple.
Old 08-30-2011, 02:49 PM
jimartina's Avatar
jimartina
jimartina is offline
Thanks guys for the great how to! i just bought my 02 Deuce and need to adjust my shocks. i'm almost a foot taller and prob 70lbs heavier than the previous owner. plus i ride 2 up alot with my kids and wife! so shock adjustment here i come! THX again
Old 08-30-2011, 06:34 PM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
On my older (99) Softail, the adjustment is on the rear of the shocks. It also has eyes at both ends so that you do not have to worry about the bolt turning. It does make it a little simpler, and I don't know why Harley changed their program. I can change mine in a few minutes on the jiffy stand also. I have lowering bolts on mine, but keep them adjusted to about stock height, because where I normally run the shocks, (soft) it hits bottom on hard bumps.
Old 09-01-2011, 10:30 PM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
Takes me less then 5 min to adjust the shocks on my 2011 Fatboy Lo, Loosen the jam nut,turn the shock, tighten jam nut, repeat on other side. You manual explains it very well and gives you the amount of turns for the load weight.
Old 09-04-2011, 11:15 PM
dieselguy65's Avatar
dieselguy65
dieselguy65 is offline
true, every one i have looked under the adjusters face the rear. i never have thought to look while at the dealer. every bike we have in shop right now the adjusters face the rear. very easy to adjust.
Old 04-03-2012, 05:57 PM
P.C.'s Avatar
P.C.
P.C. is offline
2nd Gear
Have to adjust mine on this 93 softail,i went over some train tracks and popped six inches or so off the seat!
Old 04-04-2012, 09:03 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,903 Likes on 3,014 Posts
PC, this thread is 6 months old. But there is a newer one.
DXHD $100
03-24-2013 11:02 AM
purecountry13b
10-12-2011 02:52 PM
rscott
05-09-2010 09:46 PM
johnbasf
05-02-2010 07:49 AM
96SpringerSoftail
05-11-2008 12:24 PM
Quick Reply: Adjusting the rear shocks
