Changed plugs now runs like crap
Soooo, I decided to throw in some Iridium plugs since they needed changed out anyway. She's a 2009 Heritage Softail Classic w/ 18,000+ miles. Put in the new plugs and runs like crap gapped at .40. I know the tolerance is .038 - .043...would changing the gap make a difference? I'm about to throw in my old plugs to have it run right. It idles like crap and pops like it's lean with the new plugs.
Read this and U'll know why I still use the same plugs that came from the factory..
Make sure U read what it says at the bottom of the page at least.
http://www.harleyhelp.com/sparkplg.html
Never heard that one before. I gaped mine when I ran them and they were just fine, the bike idled even better and seemed to start quicker. I do run stockers from J&P, OEM HD and much cheaper than the stealer.
As 2008crossbones said, I agree....
I was running pipes a while back without ac or tune, had a ton of pop at decel.
Swapped to the HD Screamin Eagle plat lugs (the ones for stock compression), and a set of SE wires.
Popin went away!
Great set up!
and cheap imo...
19.99 for wire set and 14.99 for a set of plugs.
Popin went away!
Great set up!
and cheap imo...
