Big Boyz head porting?
Looking to see if any one has used these guys and if they were happy with the work.
Putting on my 95" kit after sitting on it for 2 years. I decided to do the haeds at the same time. I was set to have a guy in Bristol,PA do the heads but Big Boyz wants $380 for a port job and comp. releases installed.It's so cheap I'm worried.
Does that price include new/ larger valves, guides, etc, or is it only a "clean-up?" Does it include cc'ing the heads to be sure they're the same? Does it include decking the heads for desired compression for the cams that YOU'VE selected? These things all add up, so if none of them are included, your $380 head work just went up......
EDIT....
I just checked their site, and it'll run you another $95 to have heads cc'd and decked to achieve desired compression. Big Boyz has a good following, and I'm sure they do good work, but from what I've seen on their site, you get a pretty basic port job. That's still not bad, and it may get the job done, but I'd spend a little more $$$ and go with someone like WFO Larry (www.larrysmotorcyclemachine.com), Steve at GMR Performance (www.gmrperformance.com), etc.
EDIT....
I had Hillside do some work on my heads when I did my 95" build. In all the reading I did on here though to learn about these builds, I never read 1 bad word about BigBoyz or Bean, the guy that owns the business. They offer the best bang for your buck.If you call Bean, be prepared for a 1/2 hour lesson on head work, he's a good guy as is Scott up at Hillside.
Thanks for all the info guys. I'm not going to need a head with huge valves or too much flo work. My cams are not that big (andrews 50's) and I'm not racing this thing. Just having fun on the street. One of my worries is that I'll send these heads to someone and I'll loose velocity in the heads due to oversize ports and valves.
I had a set of 2010 heads ported by BB, including cc'ing and milling for my 95" with andrews 26 cams. He did not do anything with the valves. Bean did the installation of the heads and tuned my stock ecm. I had a PC III before which we removed. The bike runs great, much smoother shifting and less engine noise. Bean is great to deal with. If you read some of the tech info on his website he talks about velocity vs just higher flow. Interesting stuff. I'm happy with what was done to my bike. The dyno numbers he came up with were lower than what I got before the head work but the previous dyno was done at another shop on a different brand of dyno machine. I'd suggest calling and talking to him.
when compression release's get sticky they should be removed, the carbon cleaned off with a wire brush and then cycle with penetrating oil. Simple to do, takes only a few minutes and makes a world of difference.
