Best & Brightest Headlight bulb ?
well it depends what kit you have, most do not have a high beam, so when you hit the switch for it your headlight just turns off.
the kit i have has an additional bulb (at most its nothing more than a foglight bulb) on it that comes on and your hid turns off, doesnt really serve a purpose because the low beam (hid) is brighter. and that my switch still functions.
the third kind that i know of the bulb actually moves out farther when you hit the switch so i guess this is the type that is an actual hi/lo set up
i guess if i had to pick which to get out of the three would be the kit i have, because if the bulb goes out while riding theres the back up in there to get ya home. also when ordering from ebay it doesnt matter which kit you buy as long as you specify the bulb type and color because all of the kits are basically the same except bulb size (all the bulbs have the same connections to the ballest),so look for a kit for a car with the slim ballests that whay you have 2 ballests, 2 sets of wires and 2 bulbs. always nice to have a back up ready so you dont have to wait on shipping when you order a new bulb. and when i have to use my back up i will order a new one right away so i have an extra bulb again.
I've seen HID conversion set-ups and I thought THEY were expensive until I saw that LED headlight that HD sells. A good bright bulb is plenty adequate and if you want to indulge, get an HID conversion kit. That LED headlamp is just ridiculous, unless it's got a built-in GPS!
In another thread some people were talking about this H4 bulb, supposed to be real bright!
http://www.amazon.com/gp/aw/d/B000TK...3845961&sr=8-2
If you are on a FatBoy with 7" then you have the Kuryakyn Option for LED which is a lot cheaper than the MOCO.
LED is plug and play, but HID requires a 'ballast' which again for a FatBoy you can hide somewhere, but for Bones,and FX bikes it is hard to find a spot for the ballast, I have not seen anyone hiding one successfully yet .
Quality of light, the HID is better at Daytime, and no real difference at night.
They both draw less amperage, which helps when you connect heated gear and other accessories.
