Do not overfill
Old 09-13-2011, 11:26 PM
Bonaro's Avatar
Bonaro
Bonaro is offline
Default Do not overfill
I am a new Harley owner. I bought a basket case and put it all back together. Having never turned a wrench on a Harley, there was a learning curve that I was forced to follow...I thought I would share.
I got everything put back together and got it started. It all sounded good so I decided to go for a short test drive. I got maybe 1/4 mile from the house and it sputtered and died. After a rew mintes it restarted and I was off only to sputter and die again a few hundred yards later. At this point I see a pattern and decided to turn around. I also decided that if it followed this pattern of sputtering and dying AND if it should not happen to restart, it was a long push home. The solution, get going as fast as possible so I could coast as far as possible before the unavoidable die.
To me this was a good plan. When I hit about 60 MPH I heard this loud POP and something hit my leg. I looked down to see LOTS of oil shooting out the right side along with much smoke...I was thinking "hmmm...thats bad". I looked up in time to make a necessary course correction away from the bridge rail then looked behind me where I noticed something chrome rolling around in the road. I thought "I need that!" The predicted sputter and die came just then so I pulled aside.
Being on the shoulder in a curve I couldnt use the kick stand. Fortunately my bike has floorboards and I can lay it over on them withoutit falling over, which I did. I walked back and retrieved my chrome which turned out to be my oil fill cap.
Lesson learned - Do not over fill the oil tank, kids, it will really get your attention. And the sputtering and dying...when the gas gauge says near empty it really means EMPTY.
Old 09-13-2011, 11:36 PM
Kowan's Avatar
Kowan
Kowan is offline
Hats off to you on your forced advanced learning curve.
Old 09-13-2011, 11:41 PM
TNB's Avatar
TNB
TNB is offline
I read something about not over filling in the owner's manual.
Old 09-14-2011, 09:37 AM
lghtngblt02's Avatar
lghtngblt02
lghtngblt02 is offline
And don't try starting the bike with the filler cap off either... don't ask...
Good work on the learning though man!
Old 09-14-2011, 10:15 AM
Wide_Open's Avatar
Wide_Open
Wide_Open is offline
I'll keep it in mind.
Old 09-14-2011, 11:03 AM
inaroush's Avatar
inaroush
inaroush is offline
Thanks for the advice!
Old 09-14-2011, 11:38 AM
pnw_hd_rider's Avatar
pnw_hd_rider
pnw_hd_rider is offline
Is it EFI or carburetor? If it's carbureted, you should have a reserve setting on the petcock.
Old 09-14-2011, 11:52 AM
parkergeorge's Avatar
parkergeorge
parkergeorge is offline
Congrats on learning something and not ruining anything in the process
Old 09-14-2011, 02:21 PM
73oldsman's Avatar
73oldsman
73oldsman is offline
Old 09-15-2011, 07:33 AM
oct1949's Avatar
oct1949
oct1949 is offline
Had a friend who stayed in Cali for a while back in the 70's. Worked at a gas station.
He Used to laugh at some of the car coming thru, Old one's that used a lot of oil.
He said they'd tell him to "check the gas and fill the oil".
Ur post me remember that.
Quick Reply: Do not overfill
