Front end wobble
Old 11-25-2011, 06:28 PM
bulldog82098's Avatar
bulldog82098
bulldog82098 is offline
I was going to check the steering head bearings first. I am betting this is the problem. I have a manual for a Dyna that uses the fall away method. Is the procedure for adjusting the Dyna the same as for the Softail? It appears that you tighten the star nut to remove the play, but what sort of wrench to you use? If someone has the Softail Service manual maybe they can check and see if the procedure is the same.
Old 11-25-2011, 10:44 PM
oct1949's Avatar
oct1949
oct1949 is offline
Check air pressure.
Check spokes to see if any loose.
Check tires to see it dry cracked or need replaced from old age.
check neck bearings TQ.
check wheel balance...
Check Pinch bolts.
one or several of these are prob U issue.
Old 11-27-2011, 07:51 AM
tbonetony06's Avatar
tbonetony06
tbonetony06 is offline
At the risk of looking ignorant, what is "fall away"? My 2006 Deluxe had a VERY SLIGHT vibration/front end wobble at certain speeds. I got a set of progressive monotube gas dampners to use and replace the front stock suspension system. I swear this thing is like riding a new bike, a dream bike! I can tell the differance like night and day, ZERO front dive too!
Old 11-27-2011, 08:00 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,541 Likes on 3,793 Posts
Best answer is it's how you check the steering head bearings on most Harleys'. Different makes call for slight different methods of what you loosen and how you adjust but search Harley fall away on youtube for a basic outline
Old 11-29-2011, 11:51 AM
jada3058's Avatar
jada3058
jada3058 is offline
Might also check the rear fork (swingarm) pivot shaft nut and bearings.
Old 11-29-2011, 02:16 PM
colonelangus1's Avatar
colonelangus1
colonelangus1 is offline
Originally Posted by watchluvr4ever
Your neck bearings probably need adjusted. A lot of people are having this problem, me included. If your bike is still under warranty I'd take it to the dealer and get them to fix it.
x2 i had same problem ..neck bearings were loose dealer did it with 8k service required for warrenty
Old 06-21-2013, 05:01 AM
abbysdad2006's Avatar
abbysdad2006
abbysdad2006 is offline
Originally Posted by Bikenator
First, you should make sure the tire pressures are where they belong according to your Manual. Then check the torque on the steering head bearings. If they are loose you might hear a slight click on hard braking...they will cause strange handling and steering issues as well if they are loose enough. After torquing them down, grease them well. There's a Zerk fitting in the center of the steering head housing meant for it.
I have a 2012 Road King and I'm getting that wobble below 40-45 mph and that click from the front when I brake hard. I have 4900 miles on it. I'm going to have the dealer look at it when I take for my 5k service.
Old 06-21-2013, 11:15 AM
Can't Ride Them All's Avatar
Can't Ride Them All
Can't Ride Them All is offline
Stage III
Oct1949 has it pretty much covered on what to check. My '03 Softail developed a slight wobble at around 8,500 miles. Retorquing the neck bearings and a new front tire took care of the problem.
Old 06-21-2013, 11:24 AM
steamybob's Avatar
steamybob
steamybob is offline
I had the same symptoms, thought the wobble was a front-end problem, but it turned out to be loose rear spokes.
flash1964
2014-2023 Touring Models
15
06-22-2017 05:15 PM
dFREDb
07-27-2013 03:51 PM
mbranscum
10-26-2012 09:16 PM
HarleyArcher
07-12-2012 09:32 AM
daniel442
07-10-2009 10:10 PM
Quick Reply: Front end wobble
