Fatboy fluids question
I use castrol 20W50 in the motor and HD primary/Tranny.
When my 1998 is on the jiffy stand, after a couple of days there will be maybe 2 or 3 small drops of oil on the ground. This only started a couple of months ago. I have noticed that the less lean on the bike, the lesser the drops., so I prop it up a little now. I suspect a shifter seal or something between the inner primary case and the tranny as it appears to be coming down the back of the inner primary.
I have checked the fluids and they appear fine, I change them every 3k miles so they are all in excellent condition, but this fluid is dark.
I cant determine which fluid it is....so finally here is my question. Can you recomend a transmission fluid that has a color like red? I am figuring if I put UV dye in the primary, red tranny and regular engine oil I should be able to have a better idea which fluid it is. I have a feeling I am going to be pulling off the primary in the next few months and replacing all the seals, but I still hate not knowing what the fluid is.
Thanks Guys.
Thanks Guys.
Someone told me about the talc and I thought he was yanking my chain..will give it a try.
Whats getting me is the fluid looks like it is old, like oil that is way past its prime. Level in my oil tank is fine and it is much cleaner and more viscous.
should engine oil taste different to tranny fluid, what should it taste like :-)
it concerns me that it only happens when the bike is leaning on the jiffy. if i put a piece of wood under the jiffy, decreasing the lean i dont see any drops. The only thing different is that I dont use stock HD 20W50 any more, since I was out of work, the last 2 oil changes i used Castrol 20W50 from Walmart. Primary and tranny are from HD dealer, bought a few a whiel ago. Bike is behaving fine and when I check the fluids I cannot detect any loss.....
I wouldn't put castrol in my hd
Amsoil oil study II
If u don't wanna read the entire study, look at the last comparison chart on pg 24.
Amsoil is pricey, so I run Mobil 1 syn.
Amsoil oil study II
