S&S 570 Easy Starts, Easy Install Complete.
Old 02-12-2012, 05:59 PM
Fierofly's Avatar
Fierofly
Fierofly is offline
Default S&S 570 Easy Starts, Easy Install Complete.
Yep, Completed my first Harley Cam swap. Bought the cams (S&S 570), gaskets, bearings, and cam bearing tool on E-Bay of course ($450). Pretty easy swap. Only goof was to remove the cams on Fri. night and go out on Sat morning and find all my oil had drained out of the tank into the drain pan, so I put new oil also, even though the old only had 800mi on it. Started it up Sat night, Now that's a HARLEY idle, sounded louder and more forceful even though I didn't do anything new to the exhaust YET. Loaded a new Power Vision Map from Fuelmoto and took it for a very short 45 degree ride. What a difference!! Can't wait for some warmer weather to really give er a go. It starts alot easier on the starter also, doesn't have that almost kickback noise when it's hot.
Old 02-12-2012, 06:06 PM
Sash302's Avatar
Sash302
Sash302 is offline
congrats dude,the cam looks little aggressive i hope you didn't lose some low end power,post some sound clip if you can...
Old 02-12-2012, 06:22 PM
oct1949's Avatar
oct1949
oct1949 is offline
Son did the 551's last yr in he new 10 Street Gl. and loves them.
With the 570 lift its close to the max of lift without doing more motor mods.
and with the 40* intake close U'll come on the cam a little later, But it looks like U ride solo and U'll probably not notice it..
When U go though the gears U wont feel it at all.
Only when U putt around 2 - 2.5K rpms U'll might be a little soft, but still probably better then stock.
Are U changing out the Pipe system,? with that cam a good 2-1 system will help Ur TQ in the lower 1/2 of the RPM's.
Old 02-12-2012, 06:30 PM
Fierofly's Avatar
Fierofly
Fierofly is offline
Exhaust. Got plans for the D&D Locat or Bobcat in a couple of months.
Soundclip alittle out of my skill level right now. LOL
Old 02-16-2012, 11:48 AM
jperez434's Avatar
jperez434
jperez434 is offline
"Son did the 551's last yr in he new 10 Street Gl. and loves them.
Are U changing out the Pipe system,? with that cam a good 2-1 system will help Ur TQ in the lower 1/2 of the RPM's."
Dude, you hit the nail right on the head. Put in the 570s and just got a tune. I'm pullin pretty decent numbers. It comes on a little later than the stock cams. Its not as jumpy off the initial throttle, but damn does it pick up speed quick. This was where I needed it when passing cars. I definitely feel the lope and the cams wanting to push past the low speed and low RPM range at 2.5k, just gotta shift a little differently.
Old 02-16-2012, 03:55 PM
oct1949's Avatar
oct1949
oct1949 is offline
I'd love to see the dyno sheet, I bet the TQ line from 2500 to around 4k is almost straight up.
Hang on to that baby, she'll jump on U.
Old 02-16-2012, 04:00 PM
dcgray2's Avatar
dcgray2
dcgray2 is offline
You're killing me!
Got the 570 ES's in my bike just can't get time to get it all buttoned back up. I went 103", got head work and tb work as well and am also using the lowcat exhaust.
I had to schedule vacation to finish my build.
Old 02-16-2012, 06:08 PM
jperez434's Avatar
jperez434
Here it is. Doesn't jump straight up, but ramps up very nicely. Definitely the best money I've ever put into this bike. The dyno sheet says 575 cams, but its actually 570 Gear Drives.
Old 02-16-2012, 06:15 PM
Marty31's Avatar
Marty31
Marty31 is offline
Got a stupid question here Fierofly.....you were planning on doing a cam swap on a motor and thought about NOT changing your oil?
Old 02-16-2012, 06:26 PM
Sash302's Avatar
Sash302
Sash302 is offline
What are the numbers I can't see them in my phone, the powerband looks good.
Quick Reply: S&S 570 Easy Starts, Easy Install Complete.
