Replacing Vehicle Speed Sensor (VSS)
My Iron did pretty much the same drove me bat **** crazy. Due to no trouble codes I recorded the speedometer not working etc on my phone. Also it only did this once it was warmed up. Harley said they were unable to replicate it. Until I told them it had to be really warmed up. He put it in the Dyno room and presto she acted up. After replacement the bike ran much better.
Glad to be of service! Forgot all about this thread since it was over 2 years ago...
Just want to add that I also ended up changing my IAC motor thing-a-ma-jig at a later date because the cutting out at stops returned. Never did have any more speedo problems though. Information on this and other forums has saved me a ton of $$$ over the years.
How does one replace the VSS? I can see it, touch it, but can't get a hex wrench in it to remove the bolt. FYI - I came across this thread yesterday, on my ride home the speedo started acting up....reading 120MPH while going about 50 in traffic. I made one stop and after starting up again, the speedo worked fine. Given the intermittent problem, I figure I would just go ahead and replace it.
Let's see.... rear wheel, splash guard, computer block, and electrical panel being held on by 3 bolts. After all that's off, the VSS is staring you in the face. Then it's easy to replace!!!
The manual spells it out nicely. If you don't already have one, it was the best investment I ever made with my HD.
Well, this VSS issue seems to be an ongoing ordeal.... I have a brand new 2015 Iron 883 and after about 1000 miles, my speedometer began to drop to zero whilst riding. I'm still under warranty, but I think I might try to simply replace the VSS myself and see if the following stops happening:
