Speedometer Glass Removal
Thanks for all the responses guys. And I will definitely check out the thread provided. To recap: Mine only fogs up. I don't really get what I would call collected moisture in the sense that tapping a hole to drain fluids is necessary. Also, it never fogs up so bad that I can't read it so it is not killing the functionality of my speedo. Finally, I just wanted to be able to clean the glass to remove the haze that has been left behind over time and not looking to SEAL the speedo completely.
If I do come up with something, I will post an update.
Thanks again.
Thanks again.
I did mine in red...
https://www.hdforums.com/forum/softa...=gauge+red+led
I still get fog in the early morning, but goes away after some sunlight and never affects my vision into the gauge.
pubscout (07-15-2022)
Lots of stuff on here about dissembling the speedo (or tach), which is great. I am looking for a replacement lens for my tach, but cannot seem to find one anywhere. Any suggestions? I was told that dealer only sells complete tachs or replacement faces, but not replacement lens. argh!
THANKS!
THANKS!
2000, california, clean, company, fatboy, fixes, foggy, glass, harley, hazing, remove, softail, speedo, speedometer, speedometers
