Installed new siren II but it doesn't come on
2012 fatboy with security system. I installed a new Siren II without a problem today. The siren doesn't chirp when I walk away from the bike and it doesn't go off if the bike is messed with. I turned the bike on and then off and put the FOB in the house. Went out to the bike and got on it. The lights flashed like crazy, but no siren. I don't have a remote pager.
Is there something I need to do to activate the siren? The directions only showed how to install it, not how to use it. I figured since it as the automatic activation security system, the siren would also be automatically activated.
Thanks!
Thanks!
Thanks!
Thanks!
1.)Is the siren plugged into the TSSM on the bike?
2.)Is the alarm battery plugged in?
Try this: this is what the Dealer does:
Make sure you put a new manual code in first. Just incase you lose your FOB or the battery in it dies.
Like this:
http://box.net/rssdownload/322671592...20page%206.rtf
Then this:
Auto Arming Function
http://box.net/rssdownload/322671394...20page%203.rtf
Then this:
Siren on/off
The new late model button less smart fobs are capable of changing the chirp mode to a silent mode. Even when armed in the chirp less mode, the siren still chirps warnings on movement and will activate the alarm through all alarm cycles.
To do this cycle quickly through arming and disarming twice, this will switch the system from either chirp less or the chirp mode to it's opposite mode.
1. With the fob present, the ignition key ON and the system disarmed, turn the ignition OFF.
2. When the system arms (2 flashes of the turn signals) immediately turn the ignition switch back ON.
3. When the system disarms, ( 1 flash of the turn signals) immediately turn the ignition switch OFF.
4. When the system arms (2 flashes of the turn signals) immediately turn the ignition switch ON and wait for the system to arm.
5. To change it back, just repeat the steps above again.
Whoever told you that is lying out their lips. I purchased and installed the Siren II for both my wife's 12 Heritage and my 09 Fatboy. Follow the procedure noted above and it'll work.
Yep, I just followed the included instruction and then took it for a nice 200 mile ride to charge the Siren's battery.
So, I rode it down to my local dealer and they activated it. Maybe a 2012 thing? Anyway, just glad it works now. chirp chirp.
Thanks!
