Please help an idiot get his forks back on
Hi.
Saturday night and spend half the day getting my forks out and another couple of hours trying to figure out the best way to get them bak in.
I have an 11 flstn and am replacing the stock forks w( damaged ) with stock forks. Got everything on the front end removed and wow what a bear to get the old ones out. Good thing I'm not re using any of it as I needed a BFH to get them out.
Went to slide in the new ones, put a little grease on the inside and prayed them open a little, but cannot get them slide back up. Mallet hitting from bottom only compresses the fork.
Am I missing a trick.. Need your guidance.
Thx tin
Thx tin
And if that doesn't work, I would put them in the freezer, then put 'em in.
Freezing the trees is going to make the holes smaller. That ain't gonna work!
You want to frees the fork tubes and heat the trees if you want to try this trick.
But as was said above, something isn't right. As soon as I loosened the pinch bolt, each fork slid out under its own weight.
If driving a flat-blade screw driver or chisel in the slot that the pinch bolt crosses doesn't do it, there's really something wrong.
