Removing burnt rubber from exhaust?
Old 04-10-2012, 08:25 AM
aniceplace's Avatar
aniceplace
aniceplace is offline
Default Removing burnt rubber from exhaust?
My wife can't keep her shoes from contacting the chrome exhaust when she rides with me. Now I have a ugly burnt rubber smear on the exhaust. Anyone have a remedy for removing it?
Thanks.
Old 04-10-2012, 08:28 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
Harley makes some black mark remover that has worked for me. Also try goof off or mineral spirits.
Old 04-10-2012, 08:54 AM
CDN 1's Avatar
CDN 1
CDN 1 is offline
5th Gear
HD Oven Cleaner. The good stuff
Old 04-10-2012, 08:56 AM
NC D'LUXE's Avatar
NC D'LUXE
NC D'LUXE is offline
Goof Off from Walmart works great. It's in the paint section. A little on a rag and it'll come off.
Oven cleaner works too but takes longer. Don't get it on your paint. Best way is to spray it on a rag or in the cap and then dip your rag in the cap or use a q-tip. You'll have to leave it soak for a couple hours has been my experience with it.
The Goof Off works instantly. Don't use anything abbrassive obviously.
Old 04-10-2012, 10:26 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Second the easy off. Let the pieps warm up and spray it on a rag. Wipe the warm pipes with rag, but not a microfiber as it will melt.
Old 04-10-2012, 10:33 AM
oct1949's Avatar
oct1949
oct1949 is offline
also U can read through some of these.
https://www.google.com/search?source...1363.11j4.15.0.
Old 04-10-2012, 12:40 PM
Ash16's Avatar
Ash16
Ash16 is offline
+1 Easy off works well
Old 04-10-2012, 02:07 PM
Rail's Avatar
Rail
Rail is offline
Mr. Clean Magic Eraser.. Used one last weekend for the 1st time and it took boot marks, baked bugs, tar, etc right off.. I mean with no real effort
The following 2 users liked this post by Rail:
BrkOut (10-03-2017), Hellbilly562 (04-17-2017)
Old 04-10-2012, 05:34 PM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
First I remove as much of it as I can with a piece of wood or toothpick while the pipes are hot. Then I try goof off, paint thinner or some other solvent to get the rest off.
One time I had a spot that just wouldn't come off with anything. Looked like the chrome was permanently discolored. I was about to give up when I thought of trying Mr. Clean Magic Eraser. To my amazement, it removed the mark that I thought was permanent. It really is magic.
The following 2 users liked this post by jimmers1817:
883 (06-25-2016), grinner (04-16-2017)
Old 04-10-2012, 05:56 PM
rscalzo's Avatar
rscalzo
rscalzo is offline
I buffed some off with Flitz. Maybe heat it a bit before with a hair dryer.
Quick Reply: Removing burnt rubber from exhaust?
