Can't get cateye console off
Old 04-15-2012, 12:15 PM
JonW's Avatar
JonW
JonW is offline
Default Can't get cateye console off
I need to remove my tank bib to send in as a template, and I can't get the cateye console on my '09 Heritage off. I've loosened the console nut but the console won't budge. I even stuck a putty knife under the rear of the console hoping to pry it loose, but all I did was destroy the putty knife. The console is not budging. Any thoughts?
Old 04-15-2012, 12:29 PM
colonelangus1's Avatar
colonelangus1
colonelangus1 is offline
the nut is the only thing holding it on so no more putty knifes just use your hands and pull like hell.there is a ribber seal/gasket around the bottom of the console its probably stuck to the paint.. my was scary i know but it will come off maybe use some soapy water around the seal/gasket
Old 04-15-2012, 12:57 PM
Madsin2005's Avatar
Madsin2005
Madsin2005 is offline
Push it up towards your bars see if it comes off the slot
Old 04-15-2012, 01:40 PM
JonW's Avatar
JonW
JonW is offline
Thanks, colonel. I smacked it a couple of times, and started wiggling it from the front to the back and it finally came loose.
Old 04-15-2012, 02:08 PM
wadejesu's Avatar
wadejesu
wadejesu is offline
Default Tool
You need the HD console puller tool, 200.00 at the dealer.
Old 04-15-2012, 02:24 PM
JonW's Avatar
JonW
JonW is offline
Is that in black or chrome?
Old 04-15-2012, 03:45 PM
brettnbama's Avatar
brettnbama
brettnbama is offline
you can get it in either, but if you take off the console without using it, it will void your warranty
Old 04-15-2012, 05:20 PM
socal yankee's Avatar
socal yankee
socal yankee is offline
And when you tighten it back down, don't over tighten. Cuz you'll choke out the motor and lose a little horsepower.
Old 04-15-2012, 05:26 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
don't forget to change your gasket too. it's $94.95 at the dealer, but $4 at any local hardware store.
Old 04-16-2012, 05:56 AM
psdj52's Avatar
psdj52
psdj52 is offline
Don't forget you also need that $100.00 tool to put it back on. HD makes them in Chrome, Vivid Black, or Denim Black.
Quick Reply: Can't get cateye console off
