Red Security Light on Speedometer but no security system?
Old 09-19-2012, 08:38 AM
uklauren's Avatar
uklauren
uklauren is offline
Florida Crew Moderator
Received 3,389 Likes on 1,560 Posts
Originally Posted by bbwilli
Harley121160, I have the exact same issue with my 2011 Heritage STC. Head lights surge, then speedometer light goes out for several seconds, then comes back on and red indicator light comes on for 3 or so seconds. The HD tech says the red light indicates the computer is storing an error code. The HD dealer diagnosed a bad cell in the battery; I didn't think that made sense and sure enough the problem is still happening. Really only notice it at night. My guess was a voltage regulator.
Uklauren, do you know if the voltage regulator recall applies to the 2011?
I don't know sorry but owners should have had the recall letter.
My speedo light still goes on and off since having the VR changed so I need to take it back in and get that looked at.
Old 09-19-2012, 08:16 PM
bbwilli's Avatar
bbwilli
bbwilli is offline
Stage II
Default Lights surge, speedometer light goes out
I plan to take mine back in tomorrow. I will post what ever they find.
Thanks
Old 10-21-2012, 09:40 PM
n2gzus's Avatar
n2gzus
n2gzus is offline
I'm having the same exact issue a s some of you have stated: headlight gets bright, instrument panel goes off, red light comes on. It is still under warranty so I should probably take it in. Bbwilli, did you find out what it was?
Old 05-25-2013, 12:49 AM
johngbrown66's Avatar
johngbrown66
johngbrown66 is offline
Default help
Anyone find out what this is, mine just started
2011 Fatboy Lo??
Old 05-25-2013, 09:02 AM
Mache62's Avatar
Mache62
Mache62 is offline
I subscribed to the thread. My g/f's 2011 Heritage has been doing the same kind of things.....dealer keeps claiming bad battery cell. Since it's under warranty they have replaced the battery. 3 new batteries since 2011?? Last time we had to pull the seat off cause there was smoke coming out from the terminals!
Old 05-25-2013, 03:00 PM
rockabillygrl's Avatar
rockabillygrl
rockabillygrl is offline
My light was coming on on my 13 heritage, I had just replaced the grips. Apparently didn't get the brake switching back together right. Have you guys found out what code it's throwing? I think to do that you turn on the run button, then turn the ignition switch on. There's a sticky somewhere around here about how to do it.
Old 08-09-2013, 10:44 PM
johngbrown66
I finally took mine in and they replaced the voltage regulator and problem solved.
Old 08-25-2013, 08:59 AM
Tada1975's Avatar
Tada1975
Tada1975 is offline
3rd Gear
Default Voltage Regulator
Is this still working? Having same problem.
Old 08-25-2013, 02:37 PM
Harley_Charley's Avatar
Harley_Charley
Harley_Charley is offline
Mine does it too since I swapped out the headlight with the Harley LED. It's alerting you of an electrical issue (mine notifies me that the bulb is out). Yours might be that you're drawing excessive power from the stereo system.
Old 08-26-2013, 11:01 PM
orrbobby's Avatar
orrbobby
orrbobby is offline
I have an 08 heritage and yes tonight red key light came on first time ever.
i will be keeping an eye on this tomorrow. I believe it is original battery.
Quick Reply: Red Security Light on Speedometer but no security system?
