Clutch Hub Removal
Clutch Hub Removal
I've done a search already but I can't seem to find exactly what I need. Please see the fiche below to see exactly which parts I'm referring to.
I fuqued up royally today while attempting to adjust my clutch. I over-torqued the push rod screw to the point that the "teeth" that hold the grooves for the diaphragm spring snap ring sheared off nearly putting out my eye!
However, the spring, seat and snap ring conveniently landed perfectly on my lap though
Anyway, can I remove JUST the clutch hub (part 9) itself without taking off everything that sits behind it like parts 15, 16, 10 and 14 etc?
http://partsfinder.onlinemicrofiche....LUTCH-ASSEMBLY
What year is it? I have my old clutch assy that has a bad ring gear. Its off my 07 FXST. It has about 100k on it but the everything else is good except the frictions and ring gear. You want it its yours. just PM me if it work for you.
Edit: Just saw you have a 91. Wont work sorry.
how i see that parts explosion is, its not a pressed assembly that needs to be replaced as a assembly. it comes in pieces. you may need a press to seperate the parts, but it does come apart. i've found that some times parts like that will come apart with a just a tap or light hit with the handle end of a hammer..
#15 snap ring holds # 16 bearing into #10 shell. #14 snap ring holds #9 hub into #10 shell through the #16 bearing.
removing 14 snap ring will allow separation of the hub and shell.
mrgforce
Panhead
11-19-2017 11:19 AM
