Removing reflectors
Don't remove the reflectors! They look custom cause no one runs them!
Sit the bike in the sun for 30 min or so then use fishing line or dental floss to cut the tape under them. Then I found rubbing alcohol worked great, but GooGone works very well too. When it's warm it will come off much easier.
Heat and slow peeling. It has been the best for me. We went on a long ride Memorial day and a freind of mine looked at me at our first stop and said hey why dont you have reflectors on your forks are they not putting them on the new bikes. I said no that is the only free mod to a Harley I know of is reflector removal. I am supprised they have not figured out a way to charge us for this yet. Anyways he said man the front looks clean now. I said lets take yours off. It was about 95 degrees here that day so his came off clean right there in the parking lot and went in the trash. So sit it in the sun or take a blow dryer and run on them for a while then twist at the center until it starts to slightly move, then grab at one corner and try to slowly start peeling. Once a peice starts to pull loose stick your finger under the 3m tape and slowly peel. If it starts to tear let it relax back a little but without letting it come back in contact with the fork and slowly start to peel again. The trick is HEAT and HEAT and do not let it tear if possible. The HEAT is the ticket though.
Let me help learn how to seach for the easy answers...
Cause this get asked aleast a hundred times a Yr in here...
http://lmgtfy.com/?q=How+to+remove+Harley+reflectors.
