Need help with rear belt
Well you will have to pull the inner and outer primary, compensator, clutch, swingarm pivot bolt, belt gard and a few other things to get it out. Here is the belt and part #. I would replace every seal you can while your in there too!
http://partsfinder.onlinemicrofiche....-AND-SPROCKETS
thanks, but when I add the belt to the part list, it says That part number is no longer available
