Want to put cruise control on my 2007 heritage.
Old 08-14-2012, 10:47 PM
skae1987's Avatar
skae1987
skae1987 is offline
Stage I
Default Want to put cruise control on my 2007 heritage.
Hi, I want to put cruise control on my heritage. Its 2007 model. I like the bike very much. But I would like cruise.
does anybody know what kind of cruise control will work.
I have heard that the cruise control unit from roadking, ultra glide, ultra classic should work on a heritage.
what do you think? If so what kind worked for you.
Old 08-15-2012, 05:13 AM
tmac00333's Avatar
tmac00333
tmac00333 is online now
Received 1,718 Likes on 1,107 Posts
I just got one of those throttle locks. Works great for me, cost around 50 bucks.
Old 08-15-2012, 07:09 AM
Bluraven's Avatar
Bluraven
Bluraven is online now
I've got what I guess is a throttle lock on my 09 Heritage and even though it's not "cruise control" when on the open highway it does work well and gives my wrist a break. I don't know exactly how a "true" cruise works but if in fact it increases throttle when needed to maintain speed then it might be worth it for under $200.
Old 08-15-2012, 07:19 AM
a99miata's Avatar
a99miata
a99miata is offline
you might check out www.murphskits.com. He sells aftermarket CC kits for different bikes. I met someone at Thunder Beach last year with a Rosta kit on his softail. He really liked it but it took about 3 hours to install. He did the install himself. It looks do-able.
Old 08-15-2012, 08:57 AM
FrozenInTime's Avatar
FrozenInTime
FrozenInTime is offline
Here's one I bookmarked, don't know anything about it or the company:
http://www.cruisemount.com/softail.html
Another:
http://mcgcustom.com/
This one I have considered, but I don't think u can use it if u have tru duals installed, which I do:
http://www.customizedcycles.com/softail_cruise/#Details
Old 08-15-2012, 09:09 AM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Good luck. Most of the OEM style units that you want have been gobbled up by those doing the same thing.
Old 08-16-2012, 07:26 AM
cwsharp's Avatar
cwsharp
cwsharp is offline
I am very happy with my Cruise Buddy. It is not the cheapest, but it is the best engineered. I suppose if I road thousands of interstate miles I might want an electronic kit but I just use the Cruise Buddy to give my hand a break. It is very easy to make minor adjustments to allow for ups and downs on relatively flat roads, but none of them will work that well in hilly country.
Old 08-17-2012, 09:34 AM
mikemnkt's Avatar
mikemnkt
mikemnkt is offline
i installed the rostra kit was really easy and i only had 360$ invested and had to cut no wires.could be done for 230 but have to cut some bike wires.only hook uo t tach wire,ground,power.tap into brake switch so cruise will shut off when hit and done
Old 08-17-2012, 09:38 AM
mikemnkt's Avatar
mikemnkt
mikemnkt is offline
and is all electronic
balloo
12-20-2016 03:28 PM
Sagexpman
05-31-2012 12:16 PM
Splais1
10-04-2010 10:37 AM
Cougfan2
01-16-2009 10:30 PM
J. Lawrence
10-08-2006 02:28 AM
Quick Reply: Want to put cruise control on my 2007 heritage.
