2011 Heritage electrical
Received 3,389 Likes
It would help if you described exactly what kind of a problem you are experiencing. Total failure? No lights? No indicators, Problem with alarm, not starting, etc etc
Have you changed or altered things on your bike that involved messing with the wiring?
Started out by the security system light flashing on...bike does not have one and the 6th gear indicator light going out.then it started having trouble finding idle..turn signal indicators sometimes would not work.after 4 trips to 2 different harley shops they finally decided to replace the voltage regulator after it killed the battery.that was about 6 weeks ago..it has done fine for a few hundred miles now its starting with the security light coming on again and the 6th gear indicator light going off again...any suggestions?????
