Looking to change out my rear wheel
I have an 06'FXSTB (Night Train) and I purchased the Magnum 5 spoke cut back gloss black wheel for the front back in Jan. I am in need of a new rear tire and was thinking about getting the matching rear wheel. Problem here is the wheel is listed as only fitting 08 and later FXSTB. My 06 has the 200mm wide swing arm as does the 08', only difference I see is 06-07' used a 3/4" rear axle and 08-09' used a 25mm rear axle.
Should I be able to buy the 25mm axle and the 08 bearing kit to make this work or is it much more involved than that?? swing arms look exactly alike.
Thanks for looking and any logical input
Joe
Joe
Hi,
This is what I used when I put a 08 rear wheel on my 07 FXSTC.
http://www.ebay.com/itm/140386363779...witem=&vxp=mtr
I also had to cut new wheel spacers and mill off a few mm's off the belt sprocket to make it all line up. Mock it up a few times to make sure you have proper belt clearance and brake caliper is centered on the disk when the wheel is mounted. I have ran the adapters now for 2 years now and just got home yesterday from a 4200 mile trip. No Problems.
