front master brake cylinder leak ?
I have a 2007 deluxe and everytime i ride i get brake fluid coming out of the front master cylinder cover I tighten it up and It still sprays on top of the cover .do I need to replace the ruber gasket between the cover or do i have to tourge the screws i just dont know what to do . When i asked my dealer he said its normal WTF a leak is normal?
I had to replace the cap on my 2011 and it still leaked. Switched dealers and their service manager (25 years experience) told me for some reason the chrome caps don't seem to leak as easily as the black ones. Replaced with a chrome one and hasn't leaked in over 5000 miles. Also, yes the screws are not put on very tight at all, I forget the torque specs in the service manual but it is minimal.
As others have said, get the revised reservoir cover. It has a much firmer gasket which does not deform as easily. Don't over tighten. Also, make sure both the gasket and reservoir are absolutely dry. You can use denatured alcohol to clean up the gasket and top of reservoir. I also purposely under-fill the reservoir slightly.
JimGnitecki
09-30-2014 03:21 PM
