New Tail Light Causes Red Security Light on Speedometer - Fix or, put stock back on?
it is a failure light b/c teh on board computer is reading their is a load problem with the tailight, meaning the computer thinks your tailight is not working and trying to warn you that its not working
the quick fix is to put in a load equalizer (resistor) and that tricks the computer into thinking everything is OK
the problem is though, if you do that, AND your tailight actually does fail you will have no idea
so the new circuit boards for the BAL have the corrected parts to fix the load inbalance and if the light actually does fail you will get the error light on the speedo, but those should be out this next month (from what they are saying)
