84-99 Questions converting from FXST to FLST
Old 09-17-2012, 06:51 PM
VoodooCLD's Avatar
VoodooCLD
VoodooCLD is offline
2nd Gear
Default 84-99 Questions converting from FXST to FLST
I have an 84 FXST that i've converted to an FL front end (94 heritage) and i'm having difficulty getting the wheel/caliper lined up.
First off my FXST had the wheel offset slightly, it doesnt look like the FL lower on the 94 are offset at all. If i get the wheel pretty close to centered, then the rotor is too close to the piston (not centered). Are the calipers different on the FXST and FLST?
On my FXST the lowers have different sized fender mounting tabs, indicating the wheel isn't centered in the forks. I don't see this on the FL, however i feel it has to, becuase harley shows the same part number for the speedo drive on the 84-94 FXST and FLST. The speedo drive is 1.4", but there isn't enough room to fit a 1.4" spacer on the opposite side.
So i guess, if someone can confirm that the FXST and FLST calipers are different , then i'll just go ahead and set it up slightly off center, and buy a new caliper.
Old 09-17-2012, 07:44 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,154 Likes on 5,390 Posts
Speedo drives are different
FX softails use 67120-84B
FL Softails use 67125-86A
Only difference between the two is the size of the spacer on the drive
Old 09-18-2012, 10:45 AM
VoodooCLD's Avatar
VoodooCLD
2nd Gear
So you think if i got the proper speedo drive, then i could use my FX caliper?
Old 09-18-2012, 10:47 AM
VoodooCLD's Avatar
VoodooCLD
2nd Gear
It looks like the FX has a spacer that is .575" and the total length is 1.410"
and the FL has a spacer of .608" and the total length is 1.426"
16 thousands hardley seems like enough of a difference to make a new part?
Can anyone verify that the 94 FL is supposed to have the wheel completely centered in the frame?
Old 09-18-2012, 06:49 PM
PanHeadRich's Avatar
PanHeadRich
PanHeadRich is offline
I'm sorry I don't have the answers for you, but you might have better luck in the EVO section: https://www.hdforums.com/forum/evo-classic-models-84/
Lot's of EVO knowledgeable folks over there.
Old 09-19-2012, 06:38 AM
Tom84FXST's Avatar
Tom84FXST
FX FL and XL all used the same caliper 84-99
Jgrasham
09-22-2016 07:47 PM
Jgrasham
09-04-2016 07:54 PM
deadeye
07-22-2011 08:01 AM
LooseMoose
03-23-2011 01:12 PM
snotrocket18
03-01-2008 01:45 AM
Quick Reply: 84-99 Questions converting from FXST to FLST
