Front brake light switch
10-18-2012, 10:17 AM
I was told by some one thayt my brake light flashes when Im riding down the road, checked it out and found that the front brake lever isnt pressing the switch all of the way so it causes it to flash on and off. Is there a fix for this?
10-18-2012, 03:23 PM
If the switch isn't broken, loosen the screws on both housings(brake & switch housing), push them together and hold while you tighten them back up. Test.
10-18-2012, 03:29 PM
I had similar problem. I bought the master cylinder rebuild kit for 35 bucks. Also, make sure you have enough brake fluid in res....
PurpleShark
10-17-2016 04:12 PM
elmo4fun
Shovelhead
25
08-27-2015 06:54 PM
fradessa
12-12-2010 09:38 PM
Route66rider
09-19-2010 09:26 PM
thejayster
09-15-2009 09:45 PM
