2012 Fatboy Lo Riser Question
I have a '12 Fatboy Lo and am experiencing upper back pain right between my shoulder blades. This happens after about 30min of riding. I was able to eliminate most of the pain by rolling the bars forward but the bike doesn't look right with the bars so far forward like that. Even the dealer said they are too far forward. Although they weren't any help with recommendations on risers. That's why I'm posting here. So...are there any risers that you guys would recommend for me? I was looking at the 4" pullback or the 4" fat risers because I'm not sure If I need the pullback or not.
Suggestions?
Suggestions?
First, if you find yourself wanting to push the bars forward, then you probably don't want any pullback in your risers. Second, you can also replace your bars with ones that are more comfortable and have less pullback too. To find where your hands fall most comfortably grab a broomstick, a friend and a tape measure. Sit on the bike holding the broomstick horizontally in front of you where you find it most comfortable - just pick the spot that feels like your hands want to naturally fall. Have someone measure the distance between the top triple tree and the top of the bar (rise), the distance from the top tree to the front of the bar (pullback), and the distance from the outside of each of your hands (width).
From there, you just use the rise, pullback, and width measurements to figure out a bar/riser combo that best gets you to that natural position you like.
Good luck.
Good luck.
Good luck.
Good luck.
You're welcome. One other note on a third possibility - which is how you are positioned on the bike. If you have a seat that currently pushes you towards the tank, you can gain a few inches of reach and height by going with a seat that sits you lower and/or farther back. My point is that if you ever considered swapping out your seat for something else, now would be a good time to do it before you go changing risers or bars.
Suggestions?
Suggestions?
Arv
04-08-2010 11:46 AM
