Changing Trans Fluid - What size is drain plug?
I went to change my trans fluid over the weekend (time to put her to bed for a long winter's nap), what size is the drain plug? I was able to remove it using an allen, but it didn't seem to fit quite right.
The oil and primary plugs are standard bolts, but this plug has no head on it, just a slot/opening in the end.
It's for a 2010 Fatty.
Thanks.
Thanks.
The tranny plug U pulled,, its the one between the shocks, right,, or,,????
this link shows u how to do it.
http://www.dudeworld.com.au/HOWTO.GEARBOX.HTML
The only plug 6-8 inches in front of the shocks is an allen hex plug on the right side of the engine, and should not be removed.
M'en F'er! I've searching the web, and I think I pulled the sump plug! Now what? Did I ruin something by pulling the sump plug?
How come the damn manual didn't just label the shocks and so forth in that diagram?
I'm so confused now, because the tranny oil dipstick was clean when I pulled that (sump) plug and drained the oil - I double checked because I thought that was an odd plug and an odd location.
This sucks!
This sucks!
