Belt Conditioner
Old 11-23-2012, 03:34 AM
olongapo1's Avatar
olongapo1
olongapo1 is offline
Default Belt Conditioner
This might be a dumb idea, but today I'm in a shop and spot CRC Belt Conditioner. Made for automotive use but it claims to prevent all types of belts from drying out, cracking and prolongs their life. So I'm wondering if anyone has ever used this or a similar product on their drive belt. Or is this just snake oil.
Old 11-23-2012, 04:30 AM
piperbob's Avatar
piperbob
piperbob is offline
Toothbrush and some water is all you need.
Bob
1997 Heritage
Old 11-23-2012, 04:41 AM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,550 Likes on 3,058 Posts
I finally replaced my 12 1/2 year old belt earlier this month at 119,960 miles. Only when I got past 80,000 would it "chirp" occasionally. Then I used a bit of grey anti-seize on the outer edge every few thousand miles to quiet it down.
My bike ran the Kevlar reinforced belt. Newer bikes, ( 04 and later,) run the stronger carbon fiber belts which should last longer.
So the short answer? No belt dressing needed IMO.
(And I never once cleaned my belt with a toothbrush or anything else. I suspect that they're pretty much self-cleaning. )
Old 11-23-2012, 07:04 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,704 Likes on 1,989 Posts
I just clean mine good with an old toothbrush when I wash the bike. Removing the dirt from the teeth helps the sprockets last longer IMO.
Old 11-23-2012, 08:04 AM
oct1949's Avatar
oct1949
oct1949 is offline
I used some belt cleaner once on the wifes car belts yrs ago.. then the Alt starting making a noise, I thought, sounded like the bearing were going south...
Took it in (Still under Warranty) and the wrench said the Alt is fine,, but he Added don't ever use that chit on Ur belt. It built up a film on all the pulleys and that was what was causing the sound. Tool him an hr to remove the film off them.
As above just a hose and soap and water, I use my wire wheel brush, its works really good for the belt too.
gerald martin
13
10-17-2021 06:21 PM
T Man
07-30-2019 05:56 PM
madwrencher
02-03-2019 08:36 AM
mikeallenbrown
08-23-2011 09:15 PM
DieHard
05-02-2006 08:01 AM
Quick Reply: Belt Conditioner
