Send help please, chrome switch housing install problem!!
I'm trying to installl chrome switch housings on my 2012 Heritage. The left side went on perfect, but I can't get the throttle cables removed from the stock housing???
They are a pain in the a$$, but there are snap rings around the tubes on the inside. they are not normal snap rings with the little eyelets, they are more like a broken ring of wire. you need two small straight screw drivers to kind of spread them and coax them off. Good luck.
Don't waste time trying to remove the spring rings. Just pull them out. They can be tough making think you are going to break something removing at times.
