Alarm?
Alarm?
On a 2006 Heritage Classic. Can you help me identify if this is the alarm. This has a red led light that stays on when I turn the key to run the engine. It is located on the frame, slightly above the crash bars. I tend to believe it is the audible speaker of the alarm system, but I can't get that part to work. The alarm system appears to be working, but there is no sound from the alarm. Can you guide me?
I'm not sure if the factory 06 alarm is different than my 09 but I don't have that box on my 09. The alarm light is on my speedo. I will note that I have the upgraded speedo-tach.
Also the speaker on my 09 is located on the underside rear of the frame in front of the rear tire behind the splash shield. I installed two $4 Radio Shack speakers instead of the Stealer $80 one, but that's where the factory connector and the speaker mount is located.
If what you show in the pic is an alarm, then perhaps your 06 didn't come with one and somebody install an aftermarket one or perhaps in 06 Harley did it different on the 09s.
Alarm and Fod
I read in another thread that if I have the fod in close proximity to the bike, that the alarm will not activate when disturbed. Tomorrow I will activate the alarm and keep the fod a considerable distance. Maybe that will tell me what this gizmo is for. I do know at least part of it is working because the little alarm icon starts blinking on the dash when the alarm is on. Thx.
My 06 is like Bluraven described. Speaker is behind splash guard in front of rear tire. The owners manual tells you how to setup the sensitivity and code with your turn signal switches. Their is a thread on how to add the radio shack speaker. Worth the $5 and some time.
https://www.hdforums.com/forum/softa...-how-to-2.html
Ok. I tried keeping the fob a considerable ways away. No sound from the alarm. If I shake the motorcycle or turn the ignition switch, both turn signals and the headlight starts to flash, plus the ignition is disabled, but that's about all. I tend to believe it is a HD alarm because there is an icon in the speedometer that flashes when it is on. Can the audible part be disabled?
Unless it was specifically equipped with the optional siren, it will not make any noise. The basic stock "alarm" is only a security system that disables the ignition and flashes the signals when disturbed. The siren was an extra option for the security system. Not sure what that box on the tubes is, maybe a fake alarm using the red light as a deterent? As was said above, the optional siren was located in front of the splash guard.
