Running rich?
Running rich?
I have a 2006 Heritage Classic, fuel injected. I removed both spark plugs, and they were mostly black and sooty. They are HD 6R12. Is this a sign that the engine is running rich. Is there a spark plug chart that shows the range of plugs. Should I run a cooler or hotter plug? Thanks
did you buy it new or second hand?
If bought second hand, the previous owner might have had it tuned and then stripped off the after market exhaust and air filter and replaced with stock items but left the tune on the ECM, before selling it on.
(just guessing here, but usually a stock bike runs lean, not rich)
The pipes tell more than plugs with modern gas. Many say that you can no longer read plugs, other than to know that they are firing.
As someone said, they are set very lean due to EPA. The question about whether you bought it used or not is probably what you should answer next. After that, does it run well in your opinion? How many miles are on the bike? What gas mileage are you getting? Is there a piggy back fuel manager or a non-stock ECM under the seat or behind the battery? After that, have someone check the spark strength.
Linking a Harley Spark Plug Cross Reference Chart for reference.
