I would think that it would fit since it's the same fuel tank. Unless the connectors are different. You could check the part numbers for the speedo and warning lamps to see if there the same. The Crossbones and Slim dash are the same.
you need the slim/crossbones speedo retaining ring, the slim/crossbones blinkers-dummy lights (the plug is the same as the Lo). finally you need to relocate the hold down bolt back 3/4" or get the slim/crossbones top plate.
