Fatboy to train front end.
From a design standpoint:
Make sure to run the smaller wheel and tire. The narrow glide front ends weren't designed to handle the stresses the large tires/wheel can put on it.
Also, the weight distribution and frame geometry may be setup differently (can't verify without further research, but seems reasonable) to account for the difference in strength and rigidity between the two.
I don't see any reason it couldn't be done. Both bikes run essentially the same frame and same front end. The differences are mostly cosmetic. The trains don't have a narrow glide front end, they are wide glide with 41mm tubes same as the fat boy (HD now has 49mm tubes, not sure what models they've made it onto yet though). Doesn't matter what tire you run, the FX front end is every bit as strong as the FL. I run a 150 on a 16x3 wheel with absolutely no issues, and that's a bigger tire than the FL's come with stock. The train trees are raked 2*, and have 2" longer tubes IIRC, so front end geometry might be a little different than you're used to.
But, do your own research first. I don't see a reason why it couldn't be done, but you might find some info that I haven't. Good luck, and post pics or it never happened!
