fatboy front wheel swap?
For the 07 and newer spacers the part numbers for left and right respectively are 41695-07 and 41502-07.
For 00-06 part numbers are 43617-00 and 43683-00. They are different. The axle on teh '10 is 25mm, 3/4" on the 00-06. I am not sure if teh hub on teh wheel is the same size or not. You will also have to get a 3/4" crush tube for in between the bearings. I am sure it cane be done but the spacers may need to be longer or milled down a little bit.
That's all I can come up with.
Thanks for all the input guys. Couldn't pass up the deal for the wheels though. Took it apart tonight.... looks like I'm going to put 3/4 bearings in it and use 05 stock spacer on right side & stock 2010 cvo spacer on left side for proper caliper clearance. Wheel is perfectly centered & true! Will post picks tomorrowwhen its mmounted. Thanks again!
