Brake light works front brake lever...doesn't work with when rear brake depressed
Yeah...dealer checked on the recall when i called on parts. No recall on my particular VIN/model.
Yeah...noticed not a lot of room. What a dumb design. and pretty crappy that it only lasted 4 years.
Don't see how you don't have to bleed the brakes. the manual says put a catch can down, unscrew old one, screw in new one (with sealant) and then bleed.
If there is any fluid loss, that means air in the line.
Thanks for the info.
Could be a wiring issue, pull off both leads, and put a jump wire in between the two leads with the ignition on, brake light should come on.
If so switch is bad, if not then it is a wiring problem.
The switch is designed to be taken out with a deep socket, and yea you need to bleed the system, not a bad idea to replace the fluid if it has not been done lately.
This is a pretty easy task.
