Easiest Install Ever - HD 4" LCD Tach/Speedo
Old 07-06-2013, 10:47 PM
Harley_Charley's Avatar
Harley_Charley
Harley_Charley is offline
Default Easiest Install Ever - HD 4" LCD Tach/Speedo
Doesn't get any easier then plug and play.
1) Remove two torx bolts
2) Unplug wiring harness
3) Remove tach/speedo
4) Remove rubber gasket and place on new tach/speedo
5) Install new tach/speedo
6) Plug wiring harness back in
7) Replace two torx bolts
To change colors etc, just follow the simple instructions. You can switch the LCD screen color, RPM color and needle color to over 600 color options. Oh, and you don't need a separate fuel sender unit/sensor either.
Old 07-07-2013, 01:23 AM
Jake911's Avatar
Jake911
Jake911 is offline
Nice mod. But can you see the tach without taking your eyes off the road?
Old 07-07-2013, 04:21 AM
P13TR0's Avatar
P13TR0
P13TR0 is offline
Stage III
How does it give the fuel level readout on your breakout without the addition if a fuel sender? Thanks
Old 07-07-2013, 07:02 AM
Pa-Rider's Avatar
Pa-Rider
Pa-Rider is offline
Did the dealer have to reset your mileage? Or is that stored in the ECU? Looks badass..
Old 07-07-2013, 01:18 PM
Harley_Charley
It uses the stock fuel sender unit. The Sportster is the only bike requiring a the use of a Fuel Sender because it doesn't come with one. All other bikes are pre-equipped with one installed.
Nope, just plug it in and your ECU tells it what the mileage was automatically.
Yes, it's actually easier to read then the stock tach/speedo. The stock unit showed the MPH with the needle and had the RPM's in the LCD portion. This unit is opposite. RPM's use the dial and LCD shows MPH.
Old 07-07-2013, 03:07 PM
FurryOne's Avatar
FurryOne
FurryOne is offline
What does this do to the "TRIP" button functionality?
Old 07-09-2013, 12:39 PM
Pa-Rider's Avatar
Pa-Rider
Pa-Rider is offline
and, ordered.. Can't wait to see it installed, up close and personal!
Old 07-09-2013, 02:25 PM
stratplexi's Avatar
stratplexi
stratplexi is offline
Received 1,002 Likes on 515 Posts
Looks great
Old 07-09-2013, 07:45 PM
CanuckWhiskey14's Avatar
CanuckWhiskey14
CanuckWhiskey14 is offline
And if you don't mind me asking , what is that worth through the dealer ? or did you find it elsewhere ?
Old 07-10-2013, 11:47 AM
RedRider0151's Avatar
RedRider0151
RedRider0151 is offline
Dealer list price is 299
Quick Reply: Easiest Install Ever - HD 4" LCD Tach/Speedo
