New Oil Blowby
New Oil Blowby
Hi! I have a '96 Fatboy with 96" S&S motor, 640 S&S cam, Super E carb, Crane Single fire ign. and V&H big shot longs. I just had the header Jet Hot coated and added V&H Quite baffles. After doing this I'm getting oil blowby. Never a problem before. I just did oil change but oil is at same level as before. I didn't think I'd have this problem just increasing back pressure. I know this is pretty vague, but any advice or experience w/ this topic? Thanks for your help.
Keep your oil level at just above the 'add oil' level and not full. Keep your revs up. By that I mean don't run slow in a higher gear, making that HD potato sound. If you need to be in a lower gear, downshift.
Lastly, you can line the bottom inside of your air cleaner cover with .... panty shields!
(don't laugh, it works. Just dont forget to change them)
