Hopefully an easy question about setting the clock on an FLSTC
Old 09-19-2013, 03:24 PM
Colorado Mac's Avatar
Colorado Mac
Colorado Mac is offline
Default Hopefully an easy question about setting the clock on an FLSTC
I own a 2008 Heritage Classic. Included in the digital odometer display, which can be toggled with a push of a button, are: odometer mileage, Trip A mileage, Trip B mileage... AND a clock. I don't have the owner's manual and have tried to set the thing by fiddling with the two buttons on the unit, but no luck.
Does anyone know how to set it, or point me to instructions online?
Old 09-19-2013, 03:41 PM
Mikeskins's Avatar
Mikeskins
Mikeskins is offline
I'd have to double check but I believe you hold the trip button when it goes to the clock then when it flashes use your left turn signal to select hours and minutes and the right to change the number.
Old 09-19-2013, 03:53 PM
08Nighttrain's Avatar
08Nighttrain
08Nighttrain is offline
I have a 08 Nighttrain but I believe it is the same scroll to clock display, hold down side/trip button for like 5 seconds till clock flashes the 12 hr or 24hr to change pust same button again once you decide hold same button for like 5 seconds and it will go to hour position push same button till you get to the hour you wish then hold for another 5 seconds and it will go to seconds and push same button till you get to seconds you want then push down button again and it should be set.
Old 09-20-2013, 06:51 AM
oct1949's Avatar
oct1949
oct1949 is offline
Turn Ignition to ACC or IGNITION.[*]Press and hold the function switch on side for 5 seconds or until 12 HR begins to flash.[*]Press and release function switch once to advance to a blinking 24 HR. Each time you press switch, it will change between 12 HR and 24 HR clock. Once you have it set on the desired time, press and hold function switch for 5 seconds. The display should change to the time display with the hours blinking.[*]Press and release function switch repeatedly to advance the hours. When correct hour is displayed, press and hold function switch for 5 seconds. The display should change to the minutes blinking.[*]Press and release function switch repeatedly to advance the minutes. When correct time is displayed, press and hold function switch for 5 seconds. The minutes display will stop blinking and your clock will be set.
4dtough
05-08-2020 11:09 AM
CADBarry
08-01-2016 08:28 AM
jp87gn
2014-2023 Touring Models
12-07-2015 07:19 PM
beggemeyer
04-17-2015 08:05 PM
glider1993
03-17-2015 02:47 PM
Quick Reply: Hopefully an easy question about setting the clock on an FLSTC
