Fatboy Turn Signal Relocator
I just installed some HD hard bags on my wife's 2001 Fatboy. I had to rove the rear turn signal lamps because there was not enough clearance to open and close the bags. It does say however in the instructions turn signals have to be relocated on all models except Deluxe. What have you guys used to relocate or overcome this issue??
Thanks,
Thanks,
Easy Brackets turn signal relocation kits are excellent quality and look great. We carry them to fit your Fat Boy.
You can find them on our website at a discount here:
https://www.deadcreekcycles.com/Soft...its_c_602.html
Don't forget you can use the promo code in the signature below for a forum member discount.
Easy Brackets turn signal relocation kits are excellent quality and look great. We carry them to fit your Fat Boy. You can find them on our website at a discount here: https://www.deadcreekcycles.com/Soft...its_c_602.html Don't forget you can use the promo code in the signature below for a forum member discount.
No wire trimming needed. You just run them behind the license plate bracket and then through a hole in the fender. Stick them back under the clips on the bottom of the fender then back through the fender to where they connect behind the brake light. Pretty easy to do and mine at least were maybe a little tight if anything but definitely don't need trimming.
Lightyear68
Electrical/Lighting/Alarm
07-28-2012 07:57 PM
flash1034
04-20-2008 11:10 PM
