Changed the oil in my 2003 Fatboy...have a question
Old 10-08-2013, 03:42 PM
fxbrry's Avatar
fxbrry
fxbrry is offline
Default Changed the oil in my 2003 Fatboy...have a question
I changed the oil in my 2003 Fatboy yesterday. This is the first time I've change the oil. I bought it a short time ago. Underneath the engine, there was a small recessed allen head nut that I removed to drain the oil. Only a small amount of oil came out. Not even a half quart. None of the oil from oil tank drained. So I then continued looking underneath and found the oil tank brain plug and removed that. Then the oil from the tank started draining. Did I do this correctly? I assume that the first plug I removed drained the oil from the engine and the other obviously drained the tank. I changed the filter and refilled the tank with oil, started the bike to circulate the oil and rechecked the dipstick, then added a little more oil to bring it up to the fill mark.
Did I do this correctly? Every internet video I watched said nothing about draining the engine. Hopefully I didnt drain something I want supposed to. Im heading out to ride the Dragons Tail this weekend and dont want to damage my bike.
Old 10-08-2013, 05:08 PM
SprungDave's Avatar
SprungDave
SprungDave is offline
That first bolt you removed was a no-no. Be careful putting it back. Tightening it too much will result in a cracked engine case. The drain plug on the swingarm is the right one to drain the oil. Otherwise, sounds like a proper oil replacement.
Old 10-08-2013, 05:17 PM
kneesinthebreeze's Avatar
kneesinthebreeze
kneesinthebreeze is offline
Read at least the owners manual before doing anything on your bike, it has all the basic fluid change info you will need.
Have fun riding Dragons Tail this weekend. Wish I was going with you on that ride.
Old 10-08-2013, 09:02 PM
fxbrry's Avatar
fxbrry
fxbrry is offline
I don't have an owners manual. Maybe I can do a google search and find one online. Thanks.
Old 10-09-2013, 09:05 AM
Mal74's Avatar
Mal74
Mal74 is offline
Here ya go! Look around the website for info on changing your trans and primary too.
http://www.dudeworld.com.au/HOWTO.ENGINE.HTML
Old 10-09-2013, 10:04 AM
peg20's Avatar
peg20
peg20 is offline
I think the workshop manual was the first purchase I made for my bike.
Old 10-09-2013, 12:58 PM
roofgunner's Avatar
roofgunner
roofgunner is offline
The NO-NO plug is put in when the motor is built. It's got something to do with assembly. The manual should be pro-active and tell you to leave it alone. I didn''t mess with it but I was curious and finally someone told me about it. You might want to put some sealant and carefully put it back in and forget it. Hope this ends well.
Old 10-09-2013, 01:18 PM
2black1s's Avatar
2black1s
2black1s is offline
You are fine. Next time though there is no need to remove the crankcase plug. Just drain the tank.
As far as all the folks telling you it's a no-no to remove the crankcase plug, don't let that scare you. As long as you put it back and it doesn't leak you are fine. The problem with that plug is when people who should never have a wrench in their hands overtighten it and cause incidental damage.
The service manual will tell you "do not remove" but that is simply because it's not necessary for doing a routine oil change. It is not because it "can't" be removed. Of course it can be removed... It's a threaded plug!
Old 10-09-2013, 01:27 PM
tbonetony06's Avatar
tbonetony06
tbonetony06 is offline
Did you inadvertently drain your primary oil? Also, did you ride and heat the engine up before you did your oil change? Lastly there is nothing you can't find on Google and getting an owners manual is one of the best purchases you can do for yourself and your bike.
Old 10-09-2013, 01:41 PM
oct1949's Avatar
oct1949
oct1949 is offline
Ur not the first and won't be the last to remove that Plug.. its the Sump drain and not meant to ever be taken out.
Usually its done By Newbies that has no idea how to change the oils.
Lot of others have cracked there case's doing it (hope U didn't) cause if that happens U get to buy a new motor or it can spend a lot of $$$ to fix because the labor cost of repairing that crack can be more than a new motor as it usually means a complete tear down and rebuild getting new cases.
heres a link that show U how to do the oils...
I'd really suggest U spend the money for a manual if U do Ur own wrenching or do a lot more and better search before U do other work on Ur bike.
If U do a search at all, there's very little that can't be found about how to work on/ or fix Ur bike.. just type in what U want to know and BAM. U'll have a lot of info..
Also most of us don't fill the oil to the top full line. It can cause blow by and come out of Ur A/C.. most of us just fill to the 1/2 way between the low and full..
And on our 07 the oil is to be checked with a up to normal temp motor and on it Jiffy stand.
U'll need to find out how it done on Ur's. Some bikes says to check oil with hot motor while upright...
Quick Reply: Changed the oil in my 2003 Fatboy...have a question
