Relocated the front turn signals on my breakout
Constant is your running light switched is blinker black is ground I don't remember which color is blinker or running light I just know I only have the blinker hooked up on mine.
If Kansas didn't require blinkers I wouldn't have any up front so I opted for one of those fancy headlights with the halo ring to stay legal.
Moving the turn signals to the front forks on my Breakout. What mounting bracket works and looks the best. One of the HD brackets sticks them out too far and they look like wings. Research on the forums says that the Kury bracket has the wrong thread pattern (some of these threads were pretty old so that could have changed).
It appears that there are two styles: 1. Clamps around the forks or 2. Brackets that bolt on to the upper or lower stock fork brackets.
I'm upgrading the stock bulbs with Custom Dynamics LED RingZ that will turn the signals into white running lights and amber when the signal is activated. Positioning first choice: forks, second choice: engine guard.
All information and opinions are appreciated.
Cowboy
Cowboy
